Item Summary: parting out 400hp RB25 power fc, 35r, injectors spitfire coil packs, plenum, head and block
Condition: Used
Reason for Selling: not needed
Asking Price: 4500
Delivery Methods: PickUp
Contact Info: 0432742160
Extra Information:
garret GT35r, manifold,tial waistgate 48mm, oil + water lines, dump pipe and waistgate pipe $1500
forward facing plenum with 90mm throttle body $450
nismo 550cc injectors x6 $450
apxei power fc with hand controler, loom and z32 air flow meter $1000
spit fire coil packs x6 $350
RB25 head Looks brand new inside has HKS exhaust cam gear $550
RB25 bottom end 88000 on the clock strong motor $400
R33 4 door 3" exhaust from the dump back, trust cannon $300
throw me offers people
call me on 0432742160 or pm me
its all on the south side brissy
MORE PICS TOMORROW
http://img256.imageshack.us/img256/6366/img0083cj.jpg
http://img132.imageshack.us/img132/8715/img0086ou.jpg
[my post count is lower than 10 so i cant reply to pm's txt or call me if ya want any info i will post at buyers expense
they top or side feed? what colour?
cheers
injectors sold
series 2
  • 3 months later...
hey mate,
how long did u have the turbo for? any shaft play etc...?
Would u post to nsw?
Cheers
  • 1 month later...
hey mate will the oil and water lines fit my 3076r? would u be interested in selling them seprately pm me
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
