Hi everyone here.
I have a difficult problem since I am doing an RB25det conversion on my 78 Mustang and I got the halfcut including the rear suspension which was not attached to the body. This is a pain in the a$$ project but I am very eager to finish it. The old suspension foundation is really not aligned with the R33 front and rear suspension system which i opt to adopt......whatever it takes. :)
My problem is we do not know the top distance of the rear suspension from the original R33.
Perhaps someone here could provide us with details/measurement.
Could you help me guys, please?
Thanks in advance.
Cheers.
Hi everyone here.
I have a difficult problem since I am doing an RB25det conversion on my 78 Mustang and I got the halfcut including the rear suspension which was not attached to the body. This is a pain in the a$$ project but I am very eager to finish it. The old suspension foundation is really not aligned with the R33 front and rear suspension system which i opt to adopt......whatever it takes. :D
Thanks in advance.
Cheers.
guys, even just the distance between the center holes of the rear tower bar would do, please. my project can't really move unless this is installed.
thanks.
