[qld] Autotek Xs 900.2 Amp (shiny!), Adire Audio Shiva 12" 600w Sub, Alpine 160w Rms 2ch Amp
For sale are some audio components I've had in storage for quite some time now, but expect to be moving overseas in a few months - so all have to go!
Pickup only from New Farm, Queensland - as they're all very heavy (and I can't be bothered posting the cheapie alpine amp). Except for the active inline crossovers, I can post those (paypal), but still prefer pickup! Have a second shiva sub available for pickup from Perth, Western Australia (that I left there when moving to Brisbane).
PM or phone 0439639394
Autotek XS 900.2 ('stealth') 2 channel amp. $280
Purpose built to have a small profile, hence being part of the Autotek 'stealth' series of amplifiers. Imported from US as wanted a high current amp (meaning can handle a 1ohm load, per channel). Manual states 'Do not use less than 2ohm in bridge mode' and 'Do not use speakers in parallel for less than 1ohm load per channel'. Power rating listed as:
- 175 Watts X 2 Channels @ 4 Ohms
- 350 Watts X 2 Channels @ 2 Ohms
- 450 Watts X 2 Channels @ 1 Ohm
- 700 Watts X 1 Channel @ 4 Ohms Bridged
- 900 Watts X 1 @ 2 Ohms Bridged
Fuse is rated at 60A, which should give you an idea of true RMS output. Other specs:
- Built in high (75..750hz) and low (40hz..150hz) filters, 12db/octave
- Subsonic filter 30hz (-3db)
- Dimensions 10.5"W x 2.3"H x 18.3"L
I'm open to offers on this one, as while I paid plenty for it when purchased some time back, I think prices have come right down. So bear with me, make an offer if you like, but I'll need to give it some time for advertising to circulate before I accept. If you can provide references to sales of similar second hand items, I'm all ears. This amp was purchased after poring over god knows how many reviews, trying to find quality amplifier for the right price. It was marketed as competition grade (whatever that means lol). Great condition but has some tiny scratch marks which you can make out in photo.
Adire audio shiva 12" subwoofer. $60
12" subwoofer rated at 600W max (one way xmax of 15.1mm). Dual voice coil (8ohm), wire in parallel for 4ohm. Think continuous power handling is in 300W range.
Not a pretty sub, but rates highly (has excellent low frequency response). If you google 'adire audio shiva review', you'll see the feedback is top notch. These can work for home cinema as well, since each coil is 8ohm.
Alpine 3542 160W RMS 2 channel amp. $20
I wanted a cheap but decent amp, so purchased this second hand. It was cheap because it's so beaten up looking (I wouldn't treat my amp like that!). Works fine though, grab a bargain!
Output Power at 14.4V:
2 x 60W @ 4 ohms (0.08% THD)
2 x 80W @ 2 ohms (0.3% THD)
1 x 160W @ 4 ohms bridged (0.3% THD)
S/N Ratio: 105dB
Fuse: 30A
Dimensions: 8.6" x 7.1" x 2" (21.9cm x 18.1cm x 5.1cm)
Harrison Labs FMOD inline active low pass crossover circuit (70hz). $10 ea
Amp doesn't have an electronic crossover built in? These crossovers are placed inline, where the RCA feeds into the amplifier, to give you a low pass crossover. Have two available.
- Crossover point 70hz
- 12db/octave
Edited by lee81
  • 1 month later...
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
