Hi guys and girls
this was our test adatronic e420c ecu we used to test on our r32 gts4
it has had about 5-10 hours use on the dyno so basically brand new.
Please find the link below with the full spec sheet of the Adaptronic
It will include the ecu with a plug in loom for r32,33,34 gtst,gtt and gtr it will also have a 3 bar map sensor so you can ditch the afm.
We can also fit and tune it at additional cost.
Price is 1200 shipped
contact on 0438 804 282 or pm
http://adaptronic.com.au/products.html
Also want to note you don't need an afm to run this ecu acts le a power fc d-jetro with a map sensor
also this ecu can be used to run traction control as well
Can you give me an idea of cost to fit and tune onto a 25 with FMIC, exhaust, pod and 9psi if I bought this from you?
Pm sent mate.
Yeah they do have lots of nifty function I wouldn't bother with the bee r as you can do the same thing with the ecu in the rpm limit control to cut the timing and not fuel or the other way it's user defined
I'd love it, but I only have a gorilla to play with so will going a Nistune w/AFM.
I can get you nistune if you want as well
I have a Z32 ECU on the way. Once that lands I'll start figuring out who I'm going to go with. There are a few reputable guys on here who I will be considering.
Hey mate it's allready 150 cheaper as it been I'm test car on the dyno for a few hours so I thought 1200 shipped was pretty fair for it
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
