Hi All,
I found a site a few months ago covering all of the import specs for each of the jap imports cars. It covered all models of say nissan in 1989 and you could choose 300zx, siliva, 180sx, 200sx, skyline, cerifieo etc and for each it had factory specs, colours, options, drivetrain, poweroutput, features etc.. even had 1994 r32 vpsec II and what it came with etc...
Anyone know of the site? You would choose manufacturer down the left hand side then model and then year of manufacture
https://www.sau.com.au/forums/topic/31593-japanese-import-spec-website/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
