Regarding checking everything,
The plan is to check my valve clearances and adjust at next service with my mechanic friend (NA_Goodness).
In my L24 tappet noise/click thread, MAG86 and Daewoo explain how to do valve clearances so i'm set with that.
Ignition Timing is all good, was checked approx 1 month ago.
Only thing i don't know about is cam timing, I'll see if my mechanic knows anything about it.
I'm going to with 25W-60 oil for next service to minimise blowby as well as topping up gearbox oil (suspect it's low).
and also which of the following should i use?
Engine Oil Flush Just before oil change. (I've heard the liqui moly equivalent is better, anyone agree?)
Long Term Engine Treatment With New Oil.
Worn Engine TreatmentWith New oil.
Lifter Free and Tune-Up With New Oil.
Manual Gearbox and Diff Treatment Add to existing oil in gearbox only not diff.
Will the bottom 3 work together without any problems?
after all that i plan to use Total Fuel System Cleaner to clean out the fuel system.
Other things include add oil to spare diff and swap in and new fuel filter.
I think I have covered all i want to do so far.
I've never bothered with any of the treatments you've listed. I'd choose a decent quality oil though for sure.
The cam timing is no biggie to check. Makes sense to do it at the same time as your tappets. Take of the timing cover and turn the engine over till piston 1 is at the top.
The big sprocket bolted onto the front of your cam can be bolted on in 3 different positions. Position 1 is for a new timing chain, position 3 for a stretched timing chain. The sprocket has a little notch cut out of it. When your number one piston is at top dead centre the notch on the sprocket will line up nicely with a little mark on the cam tower. If the chain has stretched the notch won't line up any more (I think the notch will be to the right of the timing mark from memory.)
If the notch and the timing mark don't line up you'll need too compensate for the chain stretch by unbolting the sprocket and repositioning it. If the sprocket is already on position 3 it's time for a new timing chain. Word of warning though, don't let the chain go slack at any stage, as there is a little spring loaded tensioner which will pop out of its home if you do.
The reason to bother with all of this headache is because your timing chain certainly will stretch as you start to clock up serious miles, and a floppy chain will definitely affect the performance of the car.
Good luck!
  • 3 weeks later...
Mech couldn't work out how to adjust the valve clearances, is it just one nut you undo and then move the rocker then tighten?
Service done as above but without long life engine treatment, no gearbox or diff work and used 20/60 penrite oil.
Pinion bearings are shot in my diff as well, i have spare diff to swap in (R180). On the half shaft bolts do i use a socket on the diff side and a ring spanner on the other? Tried with a mate with open ended and ring spanners and was slipping and wouldn't move. Should I spray WD40 on it beforehand?
thanks
Is your friend a Mech for a living?
Either he can't read a manual or doesn't know what an adjustible post with locknut looks like...pretty basic stuff.
Remove the rocker retaining springs
Rotate motor so heal of cam lobe is on the valve rocker arm
Undo the 17mm locknut and adjust the post with 14mm spanner.
Tighten locknut
RECHECK CLEARANCE
Refit spring (that way you know which are done)
I always loosened the locknut just enough to adjust the post because when you retighten the locknut the clearance can change.
I hope above is right (please feel free to correct people)as I haven't touched an L series in 30 years :-)
Edited by R34
He's an apprentice and hasn't worked on L series before.
The gregorys manual and L24 service manual I had on the day were very vague on the details.
I have since found the info i am looking for.
Thanks for help
Thanks for help
He's excused then :-)
Yeah Gregories are only good at street directories
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
