I do have front cut for R34 .How big cut do you need? Or just radiator support only ?? Got one in Brisbane if its help
okay i need pretty much everything from the engine forward so:
  • Radiator fan + shroud
  • Ac thermo fan
  • Radiator
  • ac condensor
  • headlights
  • bonnet lock + support assembly
  • Front Bar
  • Front bar reinforcement
  • Front Bar top reinforcement
Is the front bumper 2 door or 4 door
can you post a pic please
cheers
Daniel
https://www.sau.com.au/forums/topic/316089-r34-nose-cut/#findComment-5174292
  • Radiator fan + shroud / should have fan /
  • Ac thermo fan ??
  • Radiator / turbo or NA ?? auto or manual ??/
  • ac condensor / should have /
  • headlights / gone /
  • bonnet lock + support assembly / ??? /
  • Front Bar / dont have /
  • Front bar reinforcement / dont have /
  • Front Bar top reinforcement / ?? /
cheers
Do you actually need some front shell parts ??radiator support ,front suspension towers , inside 1/4 cut or so ???
Where are you located ??
Regards Marian
https://www.sau.com.au/forums/topic/316089-r34-nose-cut/#findComment-5174350
Regards Marian
The car is NA / Manual. what do you mean by front shell. and yes i do need radiator support and i am in sydney.
what parts do you have. like i said i am happy buying a nose cut. so essentially everything from the front of the block forward.
would like a pic and price + conditon of headlights please.
thanks
Daniel
https://www.sau.com.au/forums/topic/316089-r34-nose-cut/#findComment-5174719
Dont have picture but I do have front bare cut undamaged , radiator support up to firewall -600$ I can cut if you need rad support only - 450$ up to towers .
Got radiator - 150$
AC condenser - 220$
Fan - 80$ maybe got shroud
bonnet lock + support assembly- got it $ ??
Dont have headlights ,bonnet,bar
https://www.sau.com.au/forums/topic/316089-r34-nose-cut/#findComment-5179811
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
