Hey,
I'm wanting to get rid of these wheels and just put some stockies on while i wait for my new wheels from Japan.
I need 5x114.3 wheels, dont care what they look like but they need to clear R32/S15 brakes.
I'm not sure on the width/offset of these wheels but the fronts are pretty much flush with my fenders on front
and flush on the rear too, they will fit stock guards on the rear for a 180sx.
My front fenders are fiberglass and not sure if they are 30mm wider than stock but it should fit fine with stock fenders.
The rims weight are just over 7KG each. Here is some info on it.
http://www.auto.cons...-R_reviews.html
Comes with Tyres which are roadworthy (the front tyres 215/45/17) and rear is Kumho 235/45/17 (Rear tread is pretty new)
Must be in Victoria for Pickup only as it is trade/swaps.
IMAGES: http://nissansilvia....howtopic=433414
Depending on the Wheels for Swap - cash my way but not much.... make some offers smile.gif
Call 0431308544 or PM Me
Thanks Michael
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
