NEED A Good Spray Painter ASAP
Guest RedLineGTR
I need a very good spray painter ASAP not a panel beater just a spray painter in Victoria willing travel for a good finish. Need to get some parts resprayed for my own reasons. Also need to get a contact number off the person to explain what I need done exactly.
Does anyone have a contact or a friend that does a great job and knows skylines???
Please PM me or Call me on my mobile 0411 646 911
Thanks Rob
As I mentioned it’s urgent so the sooner the better.
Any help would be much appreciated :D
Need someone before Thursday 15th NEXT WEEK :)
https://www.sau.com.au/forums/topic/31710-need-a-good-spray-painter-asap/
Thanks Rob
most definately sam 93142647....i have seen sam paint some of the trickiest candy colours......very highly recommended
he has worked on a few....but skylines are not the be all and end all models you know....many panel shops call sam in for painting there prestige stuff like mercs ect....he has done some show stuff as well as some stuff on my 34...he is in brooklyn
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
