Garrett GT3076R, .6 surge ported compressor cover, .82 external gate 4 bolt exhaust housing
Was fitted to car brand new and driven for less than 100 metres
I paid over $1800 less than a month ago
$1600 delivered anywhere in Aust.
PM, post or call/text 0414 249 292
https://www.sau.com.au/forums/topic/317157-garrett-gt3076r/
Y U SELLING, Y U KEEP IT U ??????????????? AND HOW MUCH POWER CAN MAKE ON RB25DET WITH CAMS AND ALL MODA, PLENUM TOO THXXX
I am selling all my parts
People are making up to and over 300rwkw with this turbo
https://www.sau.com.au/forums/topic/317157-garrett-gt3076r/#findComment-5187637
hey mate still got the turbo ? what did you have it on ? do you think it would have much lag on a rb26
https://www.sau.com.au/forums/topic/317157-garrett-gt3076r/#findComment-5196732
I had it on an RB25det but not for long enough to tell you what it's like. It drove out of a shed, down the road 30 metres and back into the shed.
I'd say it would be super responsive on a 26
https://www.sau.com.au/forums/topic/317157-garrett-gt3076r/#findComment-5196740
Hey mate, why did you only have it on for 100m?
I had intentions of taking the car back to "relatively stock" using this turbo :ninja: but I spat the dummy when it wouldn't run on the tune from my old 3 litre bottom end. The turbo is essentially brand new, never seen boost, never been on a dyno
https://www.sau.com.au/forums/topic/317157-garrett-gt3076r/#findComment-5240066
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
