G'day
Friend of mine has an R33 GTST, recently he's been having issues starting it. Hot or cold, it does the same thing.
Turn key, tries to start and doesn't. Turn key again, hold accelerator on and it starts. Idles fine and it's all go after then.
We have:
Changed spark plugs
Changed the air filter
Cleaned the MAF sensor
Cleaned the throttle body
Changed oil + water
Replaced any hoses with small cracks (just in case)
Now I've heard alot of cleaning the AAC valve, so I will give that a try next. I also plan to change the fuel filter but I'm not too sure that will change things.
The other problem which may add to this is the alternator belt makes a loud squealing sound when the engine is cold, after it heats up it's fine. I haven't attempted to tighten this, someone else tightened it by simplying turning the nut on the front of the alternator but I wasn't sure if that was the way to do it or not.
Other than that, I'm at a loss and I can't think what the problem could be. He's not too mechanically minded so that's why I'm posting it all up for him.
Edited by hylian
I was going to suggest the AAC valve..
might be buggered all together but.. normally dirty ones will make it hunt..
But then if it idles all right it might not be.. ??? worth cleaning anyway..
Are you sure an injector(s) is not leaking. I too have this but my car must sit for about 12 hours before anything like the shudder only because my leak is so small at the moment. If it happens all the time it must be a bad leak!
The ACC probily wont have a thing too do with it because if it was falty it would continue too do it rather than stop after you accelerate. The only other thing i can think of is the cold start regualtor (under the stock throtle body) that may need a clean if the vavle is sticking. But my 2 cents are with the injectors
Are you sure an injector(s) is not leaking. The only other thing i can think of is the cold start regualtor (under the stock throtle body) that may need a clean if the vavle is sticking. But my 2 cents are with the injectors
How can we test if the injectors are stuffed? Or is that something that a workshop would need to look at.
I'll have a look at the cold start regulator, but it still does it when the car is warm so maybe not that. Worth a look though.
What do you mean by making it hunt?
I'm talking about idle hunting.. will rev up and down continuously on idle..
I don't think thats ur problem... if it still does it when warm (can you turn the car off and start it or do u need throttle??), I don't think it would be an injector..
yeah you have too get a pressure test done on the injectors (anyone who cleans them professionaly should also pressure test them aswell).
He will need $2900 if he wants too do it at home :)http://cgi.ebay.com.au/Ultrasonic-Fuel-Inj...=item3ef625efed
There are cheepo ways of doing it but dont risk blowing yourself up by fiddling with the fuel rail and ignition (a lot of americans have DIY for that :))
Im Almost positive its injectors because it does it when its warm. When you put the ignition on it pressureises a fuel system by priming the pump and the discription fit because i think one of the injectors is leaking heavily when he pressurises the fuel system
Could be an air temp sensor problem.
Is your mate running a pod? If he is - air temp sensor may have been disconnected.
Another problem could be a faulty tPS (Throttle Position Sensor)
He still has the MAF behind the pod filter, where is the air temp sensor located?
I'm not sure if this will have anything to do with it, but when we changed the plugs a few days ago, there was a bit of liquid around the edges of where the plugs would sit, looked like watery oil? Possibly a stuffed head?
Fiddling with the injectors and the fuel rail sounds out of my league so if it ends up pointing to that we'll take it to the experts.
Car doesn't idle hunt, it did when he blew an intercooler pipe though. We've fixed that problem.
As far as I know, turning the car off and then starting it again we still require use of the accelerator. I will also look at the throttle position sensor when I next get a look at the car.
Thanks for the help so far.
It's located in a GTR.
You'll have a bit of trouble finding one in a 33 GTSt.
I tried the suggestion you gave me (turning key to on and letting it sit for 5 secs) - didn't change anything car still does same thing.
I will have a look at the AAC and TPS this weekend.
Same thing happened to me the other day, I thought there was something wrong with my car coz it only started when I used the accelerator. Turns out it was only the battery going flat. Could it be something simple like that? Sorry noob stupid answer I know :)
  • 4 weeks later...
Same thing happened to me the other day, I thought there was something wrong with my car coz it only started when I used the accelerator. Turns out it was only the battery going flat. Could it be something simple like that? Sorry noob stupid answer I know :ermm:
I replaced the battery and it fixed the problem for a few days then it went back to normal. My guess is the alternator is about to die;
sorry about the late replies.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
