hey guys i am selling my r33 gts t its in good condition, i am the second owner since it was imported from japan,the guy i bought it from was an older guy so it has been very looked after and maintained as well as from me ,serviced every 5000 kms oil filter and motul oil . i am an auto electricain so i have kept this mechanically a1.i love this car and am selling due to me buying a gtr needs to go!!i bought this completely stock with the wheels thats all .all kms are genuine highway kms due to me driving 15 kms to work.i warm it up to operating temp everytime i drive before i leave my driveway!
$14k ono pride and joy needs to go!
*160,000 kms
things i have done:
*custom made tow bar fitted with 7pin flat plug really handy ! tounge comes off as u can see
*aftermarket tail lights look really good at night way better than the standard ones lol !
*changed rear wing
*bluetooth hands free, pairs up to any ph with bluetooth
*all oils changed 1000 kms ago
*brand new hybrid intercooler from performance wise in sydney
*new rear bushes in whole of rear and that was a mission believe me
*new rear wheel bearings both sides
*all disks machined and new good quality european pads applied
*brand new exceedy heavy duty clutch
*link engine management withh 3bar map sensor tuned very nicely running 12 psi havent pushed it! comes with hand controller
*new hicas lock bar
*new hicas ecu installed
*starter motor recon
*alternator recon also have a spare one that is also all reconditioned if wanted !
*brand new yellow jacket high performance coil packs from performance wise in sydney!
*clarion head unit dvd compatible valued at $550 with 700 watt amp and earthquake 12 inch sub in box,clarion 6x9 in parcel shelf and 6.5 '' splits in front
*new driver side electic window motor
*vdo boost gauge
*new chrome insert headlights off a gtr with all good blue bright bulbs
*new shocks and lowered springs done about 10000 kms
* air condtioning works and is cold, recently been serviced ,regas,new tx valve.
*custom cold air intake and custom heat shield on pod filter gives better fuel consumption and gives it more response
*standard blow off valve sounds good though. runs really well ,holds boost right through
theres probably more things but cant think of everything this car is in good nic and mildly modified wright and proper. i have owned this for bit over one year! been a good car never missed a beat or caused me probs. motor and turbo in really good condition.18'' deep dish wheels 265 tyres on back and 235 on front. been very reliable . but needs to go as i am buying a gtr cause i love skylines for many reasons lol!the only thing wrong is i recently hit a possum on way home and damaged front bar not that bad though!
please pm me if there are any questions
reguards dan.
if more pics wanted just contact me all interior in good condition also !java script:PopUp( // http://www.skylinesaustralia.com/forums/danny14-m59423.html
one photo there before i lowered her and changed the wing smick condition as u can see !!
Edited by danny14
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
