due to me being a P-plater on 1 pt left and not wanting to risk it i have to sell my soarer .... has rego till june ... its an auto
FANTASTIC SOUND!
its a 1jz-gte 2.5l twin turbo
its done 158,xxx ks
perfect engine condition
never had a problem and starts 1st time
doesn't blow smoke
interior condition is average, some cracks in plastics etc
paintwork also average, still looks good but some scratches (small) and paintfade
mods are:
FMIC
Pod filter
Exhaust (3" downpipe into spit 2x2.5") sounds great
17" rims
Headunit
there are a few things cosmetic you could do 2 fix up the car but overall its pretty great and ive never had a problem
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
