Hi,
I am selling a set of Genuine Ohlins Coilovers for an R34 skyline. They came off an R34 GT-T but the part number also fits the R34 GTR. See ohlins website below:
http://www.ohlins.com/Our-products/Automot...ts/RT/NIS-MI10/
They are height and dampener adjustable.
They are in great condition as per the pics.
Price: $700 for both front and rear.
Located in Melbourne put can post at owners expense.
Jeff 0400648813
They will fit both sedan and coupe.
I measured the springs up last night:
- Inside diameter: 72mm
- Thickness of spring: 12mm
- Number of coils: front 7 and a bit, rear 6 and a bit
Now I just need to work out how to calculate spring rate from this. I dont think sydney kid is on here anymore. I was thinking about reading through that thread and looking for springs of similar dimensions to get an idea on the spring rate.
I showed them to a suspension place and they said one of the rear coilovers had a leak.
I will sell them all for $200ono seeing as one of the rears has a leak. The other 3 are fine.
Edited by Harey
You have pm
pl call Alex 0433878905 Mordialooc 3195
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
