hey guys just rego'd this car had it for sale for a couple of months , had alot of interstst but people were iffy about it cause i was selling un regoed.
so i just regoed it 4 days ago and im seeing what interest i can get back on it
so car will come with 12months reg and im supplying a roadworthy.
keen on swapping for a 32 gtst,s13/180
or 6k
mazda rx7 fc series 4
black
turbo
manual
sunroof
95,xxx km
interior is immaculate hence the k's on it
aftermarket rear bar
side skirts
car is stock as a rock, standard exhaust only thing that was on it was pod last year
car starts fine, runs fine and drives fine.
let me know if your interested and what you guys got. or if you want to buy just give me an offer
cheers
contact me on 0412-219-552
Edited by tin-pain
https://www.sau.com.au/forums/topic/318350-rx7-fc3s-12months-reg/
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
