FOR SALE
Hypergear turbo ATR43 G3 500hp about 5,000 kms old
Awesome turbo made 301 rwkw on 22 psi selling due to car being defected so it has to come off and i wont be refitting it as the car will be sold
comes with braided oil feed line and custom oil drain pipe, factory waterlines fit up no worries also come with a 14 psi actuator and a 19 psi actuator which cost me an extra $150 alone
Asking $1000
PM or call 0417 899 445 cheers
to suit RB25det
https://www.sau.com.au/forums/topic/319317-hypergear-atr43-g3-500hp-turbo/
it fits straight up u will have to mod ur intake and put a 90 degree silicone bend to the cooler pipe otherwise it will bolt on dump pipe fitted up normal on mine and didnt make the exhaust sit a bit back or funny at all
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
