My RB25 did exactly this same thing when it had the twin turbo setup. It was due to the turbos forcing more air than the engine could take at low rpm so the air choofed back thru the filters. At top end this problem was gone and made good power. (399rwkw @ 17psi)
I changed from the twins to a T51r and the problem was gone. I was told it will damage the turbos as the exhaust wheel turning one way and the extra air trying to turn inlet wheel the opposite....
So is this true that it can damage the turbos mate?
Can anyone verify this?
I might have to fix it by going back to the plumback setup if it is.
Ah ok i was going to say the power sounds about right for 1bar give/take, and given a built motor crank it upto 20psi and see 380rwkw :)
Comp surge especially whilst building boost is bad, you are fighting two forces at once.
Backing off throttle isn't such a worry though (the other type)
I was told by a few places that it puts added stress on the turbo shaft as the wheels try going different ways as the pressure comes back thru the compressor cover.
I also tried the same twin turbo setup on a 25/30 and had the same result just with the choofing noises at lower revs
Maybe a question for the tuners....
Would it make much of a difference changing the cam timing to clear up the surge...?
So how exactly does the plumb back setup solve the problem?
Wouldnt the extra air that is escaping through the compressor cover still escape, only instead of escaping all the way back through to the air filters its just get resirculated back into the intake?
Im just trying to understand how the plum back would solve the issue of too much air geting forced into the engine at low revs. As surely the same amount of air is geting fed into the engine plum back fitted or not........?
Have a read of this thread - http://www.skylinesaustralia.com/forums/Gt...-F-t160901.html
It can be tuned out. It's also possible your wastegates aren't set the same causing one turbo to try and run more boost.
I run the trust/greddy piping too with hks 2530s but i have the standard bovs. Only rarely got the shuffling going up a hill in 5th.
Thanks heaps for that man. Thats exactly what I was after!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
