Hi, having problems with my r33 series 2 at night. the car seems to start fine and lights work fine too at first. but after driving it and having to come to a complete stop the headlights start to cut out when its idling. and the car feels like its struggling not to stall.
it also seems to be more the one headlight then the other.
and when i pulled over to check the car out the other night one of the tail lights was also out but now its working again.
anyone have any experience with this or know what it could be?
had a look around for similar problems but getting different answers. have no idea myself really.
wondering if it could be a faulty relay caused by overloading current from braking? or maybe a vacuum hose leak or even a bad ground connection with engine and chassis?
don't think its related to the battery or alternator tho.
any help????
actually the car is idling fine. i thought it was idling low but my mistake.
its just the low beams turning off as you come to a stop.
the car has been taken to an auto electrician and he could not fix it. he thinks its a wiring issue but couldn't work it out cos he couldnt find any headlight wiring diagrams. either could i. but its not the alternator or relays.
took the car for a drive with my brother and did a few tests and it seems the lights are triggered by the speedo and the brake being applied together.
you can also hear like a relay or switch clicking as its triggered.
ive read through some topics and found that in japan they all tend to turn the headlights off at traffic lights and they may even be a device that can be fitted to do this automatically.
thinking now that my car may have something like this which is weird cos ive never heard about it.
anyone know anything about this or can lend some advice??
kinda stuck might have to keep tryin auto elects or even a compliance place.
cheers
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
