Selling a set of DTM rims in hyper black finish - 18x7.5's for the front and 18x8.5's at the rears. Offset is +32 at the front and +40 at the rear. Stud pattern is 5x114.3 and they fit on 200sx, Skyline GTS-T, Supra, RX7, 300zx.
Fitted with Falken FK451's which are 225/40/18 at the front and 255/35/18 at the rear. Tyres have 90% tread front and rear.
Wheels are in excellent condition apart from small kerb marks on 2 rims. Asking for $1,700 and I'm located in Sydney.
Email to [email protected] if interested.
These look like Vertec VR5 Quests made by Manaray Sport, which look amazing in the flesh.
Interested, but would like to see close up pics. Im in Perth but can provide a Sydney delivery address.
Oh BTW these should fit without rubbing, i had what looks to be the same rim priced up new in a 8 and 9 inch combination which I was assured fits perfectly on 32's and 33's.
Red17
hi all, thanks for your interest.
moo_r32 - sorry i don't have any other pics and i don't own a digital camera. yep, they fit on 32 and 33 gts-t with no probs, no guard rolling required. i'm selling cos i sold my car and i'm just trying to get some of the money back that i've spent on aftermarket bits.
red17 - the vertec vr5's are identical to the dtm rims and they're actually both made by manaray sport. the manaray brand is actually stamped onto the back of the dtm rims. sorry, no closeup pics unfortunately. yep they fit perfectly with no rubbing, just bolt straight onto 32 and 33.
h3roic5 - check your inbox.
most of the interest i've had has been from perth, wa. if buyers are interested in paying for freight, i'm keen to sell, but i have no idea how much this would cost.
cheers.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
