Have skyline, R33 gtst 93, with many extras but need something that can transport more goods + people. Prefer 97-00 wrx wagon (Blue?) with mild mods, Exhaust, mags, front mount, ecu..... etc
The skyline has many mods,
Apexi bar and plate intercooler
HKS gt2530 ball bearing turbo
exhaust, including split dump pipe
chrome 18s
gtr bodykit (front 400r bar, side skirts, GTR wing)
boost gauge + Tomei air fuel gauge - mounted on side pillar pod
suspension
HKS turbo timer
Apexi powerfc with hand controller
Pioneer mp3 cd player
GFB stealth bov
HKS pod filter
Turbosmart boost controller with rocket launcer switch
spare R33 GTR front bar
Dyno tuned by UAS at castle hill 216 rwkw
New belts (inc. timing belt) and plugs
neat and tidy, body is straight, with under 60000 on the clock.
$27000 with mags (they are only 2 months old)
$25000 with standards or...
As i said swap for hatch wrx (with cash adjustments either way), the missus wants something that "feels safer" she doesn't like rear wheel drive.... anyone interested email me [email protected] for pics or more info.. cheers
https://www.sau.com.au/forums/topic/32092-mod-r33-gtst-swap-for-wrx-hatch/
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
