Parts left over after the conversion, need the space back. Panels are black, from an S2. Will consider offers for the lot aswell with a $100 packing fee if it goes interstate.
Bonnet and hinges $165
Bonnet dampers $60
Guards L & R $110 (Passenger guard has a ding near the headlight)
The long metal parts the guards bolt to in the engine bay L & R $30
High beam L & R $75 each
Grille with badges $60
Front bar $40 (Has a small crack near the passengers headlight can be welded, and the usual small scratch's)
Reo $50
Indicators and foglights (front bar) L & R $25 each (Plugs have been removed but can still be wired up)
Bonnet catch and support $60
Stock airbox with panel filter and snorkel $80
Stockintake pipe with stock oil and BOV return pipes $40
Stock side mount with return piping $50
LHS passenger door COMPLETE, $90 (door skin is toast though)
Stock BOV $20
From an S1
Power steering reservoir $10 (can be used in pretty much any skyline though I think)
Auto trans cooler $15 (average cond)
Washer bottle with motors $20
Condensor $15
Stock horns $10
S1 nose cut wiring loom with Bosh 35w HID ballasts with separate fuse box $30
Also have the rear flares that came with my conversion gear seen in the first post here for $80
Alpine head unit with manual and remote (worked when I pulled it out) model number CDA-9811 $25
S15, came off at 60,000km's
Stock camber, traction and toe arms $40
Stock side mount with most if not all piping $50
Stock DIN pocket, hole cut in back for EBC wiring $20
Stock A pillar Garnish (no gauge cup) $30
Pretty sure thats about it, all prices are not including postage, Please TXT 0409077592, email [email protected] or PM me. I'll put pics up if anyone is interested.
Cheers,
Teren
damn!!!
iv been after a set of rear flares for 3 years now! i have front ones in the shed. DAMN!!!
oh well, the hunt continues........
D.
Bonnet dampers $60
Reo $50
$680 for the lot!!! (excluding postage and packing fee if going interstate) :ninja:
Condensor $15
Stock horns $10
$50 for the lot!!! (excluding postage) :(
$100 for the lot!!! (excluding postage) :)
Edited by Tangents
will sms you in the morning teren to organise payment for the flairs!
:ninja::P:D:(:)
sorry dave,i tried to buy these flairs first time they came up
couldnt interest you in selling your front pair could i?
pm me if you want dave
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
