For sale
Datsun 1600
good condition
new roof lining
new carpet
new dash(no cracks/fade)
sports seats(mod plated)
L16
twin dellorto carbie
extractors
battery relocation
runs well
For more info Pm me
price $5000 ono
feel free to make offers am very negotiable
thankyou for looking
https://www.sau.com.au/forums/topic/321367-datsun-1600/
hey mate is there any rust in the body?
hey mate
theres bugger all rust mate
none behind the back wheels which is where they usually rust 1st
theres a little blister on back right left door, bout size of thumbnail( just paint bubble)
thats about it
even with the paint on roof peeling theres no rust there
very clean car
sand it back and paint it and your done, if you wanted to
you might find little rust spots here and there when you sand it back, but wont be much, you wont even have to fix it, just surface rust at most
you interested???
need sold asap so i am taking offers
https://www.sau.com.au/forums/topic/321367-datsun-1600/#findComment-5244337
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
