For sale or swap, my a31 nissan cefiro.. very reliable car, i drive it everyday taking my kid to school, shopping lol etc etc
Interior is near immaculate. Been told the interior pattern is quite rare aswell.
202xxxks on the shell
Engine
RB20DET conversion approx 130xxx kms
JJR FMIC,
3inch exhaust dumped after diff, no mufflers!! sounds angry
NGK plugs
Dr. Drift custom tune to 169.1 rwkw
Gates sport timing belt and tensioner
Driveline
5 Speed manual conversion
R33 GTST Shimmed LSD
extreme extra heavy duty solid button drift clutch(rated to 650hp) not very old..
new 3 inch thick wall 1 piece tailshaft
Wheels/Brakes
S15 Front Suspension Conversion
Lovells Sport Springs
KYB Struts
Hicas Lockout Bar
5 stud Conversion
R32 GTR Front brakes
R33 Rear brakes
Volk GTP Rims (17x9 +33, 17 x 8) new tyres, 95% tread
Rays gold wheel nuts and valve caps
Bendix Brake pads
Other mods
new water pump
Bosch 044 fuel system
alloy radiator
thermo fans
mushroom pod filter(new)
Boost tee(new)
Recaro Drivers seat
Momo gear knob
Speco Boost gauge
Alpine Type R front splits
Alpine Type R rear Splits
Double din dvd player/screen
battery in powered box in boot
new fully synthetic oils allround, recently been pitted and registered!! passed pits without a problem!!
$10500 or swap!! hit me up with wat ya have.. doesnt bother me if i dont get rid of it, ill just keep spending money on it!!
sms 0409402860 or pm
https://www.sau.com.au/forums/topic/321700-nissan-cefiro/
  • 1 month later...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
