Item Summary: Bmw 318is,Fresh Paint,Lowered,Black M3 Rims,Immac cond,MUST SELL Manual,Long rego, HEAD TURNER / SWAPS
Condition: Used
Reason for Selling: Moving interstate
Asking Price: 9900
Delivery Methods: PickUp
Contact Info: 0421878209
Extra Information:
1993 BMW 318IS 2 DOOR COUPE
Recent service
Cross drilled brakes
Chrome twin exhuast
Gloss black M3 rims 225/45 profile tyres
Fresh paint in and out / Gloss black bonnet
Lowered on King Springs 3inch rear 2.5inch front
Lipped guards
Clear side indicators
Tinted windows
Short shift / momo gear knob
K & N panel filter
Pioneer head unit
Sony splits
No accident history
Inspections welcome
2 Door
5 Speed manual
No dints/scratches
Pwr steer
A/C
Pwr windows
Always garaged
Always servicedon time
NO oil leaks
RUNS VERY VERY SMOOTH
INTERIOR IS IMMACULATE AND CLEAN..SPOTLESS NEARLY!AS NEW.
CLASSY,SPORTY,COMFORTABLE,ECONOMICAL,RELIABLE
http://www.boostcruising.com/forums/index....howtopic=577595
pics
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
