APEXI AX53B70
$2000 ono
mint condition (as new)
paid 2400 for it w/o lines last october
bought it brand new and did one track day on it before i stripped the car.
would have done less than 500km at 15psi
there one of the most torquey turbos on the market
t3 flange for rb20/25
these turbos make 250 on rb20's and have seen them make 300 on a forged 25, not sure what they make on a standard one though.
comes with all fittings and braided lines to bolt straight up to rb20/25
internal gate,
its the p25 model (basically just means skyline flanges)
here are the comparisons to a hks gt-rs
Apexi ax53b70
Power
380PS
Compressor
Trim 57
Comp Inducer 53(mm)
Comp Exducer 70(mm)
Turbine
Trim 82
Turbine Inducer 53(mm)
Turbine Exducer 48 (mm)
Housing A/R
P25 (1.01 A/R approx)
HKS gtrs
400 PS
Wheel- 52 Trim - 51.2 Inducer / 71.1 Major
-Housing- 60 Inlet / 50 Outlet - 0.60 A/R
TURBINE:
-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer
-Housing- GT25 inlet / Internal GT25 outlet; 0.64 A/R
Edited by flame_this
https://www.sau.com.au/forums/topic/321831-apexi-53b70-turbo/
I have one of these turbos and it is awsome.I just don't understand what rear housing size it is.Like you can get a garret 3076r in .63 or .82 if you want more top end power,so what would this turbo be?
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
