I'm looking a few parts, but are in no particular hurry for them, but please let me know what you have and what you are chasing for them.
  1. R33 smooth finish ashtray
  2. GTR brake air deflectors (they bolt to the castor rods)
  3. R33 rear RIGHT tailight in any condition, I just need the black plastic housing, mine has broken where the globe sits in.
  4. Rear camber arms to suit R33 GTR
  5. Front castor arms to suit R33 GTR
  6. 1 PAIR of 17x9 rims with no more than +30 offset. Drifteks, etc (just want them for skids) - prefer Adelaide obviously, the cheaper the better, no tyres required.
  7. intercooler Hard piping kit to suit a GTR, more specifically, only need the top two pipes.
  8. Hard intake piping to suit RB26
  9. Clear RB26 cam cover - new or near new
  10. HKS fuel rail to suit 10.5mm injectors
  11. Genuine S1 R33 GTR front lip or aftermarket (Jun etc)
  12. The little clips that glovebox hinges on
  13. Aftermarket steering wheel to suit R33 S1 (momo, nardi, etc)
  14. R33 GTR Nismo Cluster 320kmh
that should do it for now...
i have a MOMO steering wheel, it's missing its horn (some f***er stole it when it was being imported). Let me know if you're interested, wheel is in new condition, I'll get some photos up.
I'm really only after a suede finish wheel complete with horn button, but thanks anyway!
still after the following:
3. R33 rear RIGHT tailight in any condition, I just need the REAR black plastic housing, mine has broken where the globe sits in.
4. Rear camber arms to suit R33 GTR - no longer need
6. 1 PAIR of 17x9 rims with no more than +30 offset. Drifteks, etc (just want them for skids) - prefer Adelaide obviously, the cheaper the better, no tyres required. - no longer need
8. Hard intake piping to suit RB26 - no longer need
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
