Hi there I'm after 740cc nismo injectors for my rb25det r33 gtst or sard 850cc injectors
but they have to be side feed so they go on stock rail....
Where is the cheapest place to get any of these injectors?
I need injectors asap!!!!
Please help me out! Thanks
https://www.sau.com.au/forums/topic/323125-wtb-rb25det-sard-or-nismo-injectors/
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
