item Summary:1990 Nissan Sileighty.
im ony interested in swaps for a R32 or a R33 if you have one or know of one contact me via PM also contact me via pm for full details of car.
Pics: here are a few pics from what it was when i got it & as it is now.
https://www.sau.com.au/forums/topic/323199-sileighty/
Hey mate how much cash do you want for the car
https://www.sau.com.au/forums/topic/323199-sileighty/#findComment-5283777
as stated before i can't edit my posts for some reason so ill have to put the details in a new post yet again ;)
its a 1990 180sx/Sileighty
S13 Front conversion
CA18DET
97,xxx k's might even be less
5 Speed
Bilstein Coilovers
Nismo style side skirts
Front & Rear Strut Braces
Nismo 3point race harnesses
5" tacho with shift light in cluster
Digital Cluster
pioneer cd/mp3 player
stripped rear interior ( still have everything )
aftermarket type X style tinted taillights with Type X RPS13 Carbon fiber center garnish
full 3" exhaust into 3.5" cannon
has a set of 16" jap rims but can come with a set of almost new 18" Lenso rims with brand new tyres
thats all i can think of atm ill post up more as i remember
https://www.sau.com.au/forums/topic/323199-sileighty/#findComment-5289471
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
