Guest sssnowdon
FEATURED IN AUST.INCAR ENTERTAINMENT"
Spent over $35000
Features include;
BODYKIT
Full usc custom bodykit with vp v8 supercar rear wing,ser3 t/lights,prof.lowered 2'with whiteline springs and monroe shocks and new w/screen
INTERIOR
Complete custom saas interior including saas avenger front seats,retrimmed and rebolstered rear seat,custom door trims for stereo install,momo s/w ,g/knob,custom mats,c/fibre dash kit
ENGINE
rb30n/a 5sp,new 02 rush air filter with custom perspex cover,extractors with custom s/steel cover, 2.5'exh,hi-flow cat,mild head port and polish,new lifters,custom s/steel injection cover paragon 500 alarm, faultless detailing in eng. bay
WHEELS AND TYRES
New citic 18'by 7' chrome rims with new falken grb rubber
STEREO EQUIPMENT
H/u sony xrc 750with remote,sony cdx45 10 stack cd player
AMPS;rockford fosqate punch100,punch4020 with heatsink extension
SIGNAL PROCESSING;pheonix gol eq232 dual 30 band eqwith balanced line t/mitter
SPEAKERS;mb quart 3 way front splits, 2 four' r/ford f/qate center channel,sondstream b69 rear fill,2 kicker 10'subsin ported perspex box,ph.gold half farad capacitor,ph.gold rca's,coustic multy channel crossover,streetwires cabling.
STEREO FEATURES
Full custom install including equipment recessed in boot floor,subs in perspex box with neons and halagen lighting,dual 30 band eq recessed in boot lid,custom moulded front door trims for 3 way splits,neon display in glovebox,separate bass control in front ,custom rear p/shelf.
receipts for $12500
SPARES
2-95percent 18' michelen tyres,1 new rear bumper.all original seats etc,original wheels and tyres,complete bottom end only travelled 60000 klms.
CAR HAS TOO MANY MODS TO MENTION.REDY FOR SHOW N SHINE OR AUDIO COMPS,IMMACULATE COND.WINNER OF 12 TROPHIES,11 MONTHS REGO."14000ONO.
STEVE AKA SSSNOWDON
POST HERE OR EMAIL [email protected] OR PHONE 0438219922 VICTORIA
_________________
EMAIL ON [email protected]
Below are recent pictures.
PRICE REDUCED TO 14000 ONO SEE OTHER POSTS FOR PICS
Logged
Pages: 1 Reply Notify of replies Send Topic Print
Forum Jump: ----------------------------- General ----------------------------- - Announcements - General Discussion ----------------------------- Technical ----------------------------- - General Questions - RB30 Questions/Mods - RB20 Questions/Mods - Car Audio - Other ----------------------------- Events ----------------------------- - Upcoming Events - Past Events (reflections) ----------------------------- Trading Post -----------------------------=> For Sale - Wanted to Buy - Swap ----------------------------- Other ----------------------------- - Feedback
https://www.sau.com.au/forums/topic/3232-r31-showcar-price-reduced/
  • 3 weeks later...
  • 3 weeks later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
