Item Summary: Tomei HICAS Lock II
Condition: New / Opened Box
Reason for Selling: Not needed
Asking Price: $150
Delivery Methods: PickUp
Contact Info: PM or post
Extra Information: I received a Tomei Lock II kit, along with some other goodies the previous owner hadn't fitted yet, after purchasing an S13.
I'd prefer to do the mechanical HICAS lock to shed a bit of weight so looking to sell this kit.
The box has been opened so I'm not sure if it's complete (it looks like it is though) but it is new. It's also a genuine item.
For those who don't know, this is a convenient way of locking HICAS without all the mechanical nonsense involved. It's also easily reversible should you want a better turning circle
This will suit pretty much any vehicle with HICAS
There are no english instructions though although they are available online. Basically it interrupts the signal received by the HICAS computer to tell it everything's OK and there are two shims which lock the rack underneath.
Can meet in Brisbane or post at buyers expense.
Sorry for the poor pic.
https://www.sau.com.au/forums/topic/323515-tomei-hicas-lock-kit/
  • 2 months later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
