Family car, second owner have had car for 5 years
Regular service
Duel Fuel LPG installed 2008
Sunroof
Electric seats
ABS brakes
Airbags
Automatic
16" mag wheels
Low kilometers 175,000km
Price: 9500 obo may swap
comes with Rego and RWC
call: 0431 366 941
located Melbourne st albans
https://www.sau.com.au/forums/topic/323822-holden-vx-lumina-2001/
