I HAVE BRAND NEW, ONLY TRIAL FITTED R32 GTST CLEAR INDICATORS. WANT TO SWAP FOR THE COMPLETE ORANGE ONES PLUS CASH MY WAY. I BOUGHT THESE FOR EXACTLY $201. STILL HAVE RECIPT FROM JAPAN FOR PROOF. NEED ASAP!!
THANKS
Uploaded with ImageShack.us
https://www.sau.com.au/forums/topic/323884-new-r32-gtst-clear-indicators/
Any chance you would sell them without swap? My orange ones are alittle banged up. You can then find some yellow ones elsewhere.
Thought I'd ask
Edited by mark_sudakov
Thought I'd ask
yeah it's come to that now. Make an offer and there urs
Let me know how much u want.
Just a thought, there's not any defect shit possible with these is there? Like do they light up well?
they light up like the normal indicators, if anything bighter.
But I'm probably after around $150 mark , but like I said if it's to much, throw some offers my way. As these are brand new, and I still have the Recipt to prove how much it cost me. As these are from japan!
  • 2 months later...
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
