Hey guys and girls,
Up for sale I have a genuine Greddy Intercooler Core, Has been used but is still in good condition.
Am selling due to choosing to run a GTR Intercooler instead.
Asking $150 or nearest offer
Located on Sunshine Coast, can organise postage if needed.
Pm me or post on topic.
Cheers,
Kails
will upload other pic of complete cooler core shortly have to make a jpeg won't let me upload gif files
https://www.sau.com.au/forums/topic/323936-greddy-intercooler-core/
