Well times are tough ... the end of my rental lease is coming up and the agent has informed me that the owner is going to knock the house down and develop the block ...
and I am having a hard time trying to find another rental place with the ammount of stuff I have I will have to downsize big time ... so time to sell a couple cars ...
Up for sale now is my skyline ...
Model :- 1992 HR32 GTS Nissan skyline
Engine :- RB20 DE (non turbo motor ) (250,000km on motor mainly highway km from previous owner travelling from QLD back to canberra for university)
I will be completely honest the engine is a bit low on compression across the board but it starts and runs fine ... has not broken down on me ever since owning the car and is reliable enough to jump in and drive up to QLD or down to melbourne any day of the week regular oil and filter changes every 5000km with 10w 40 oil ... Car has no oil leaks from anywhere
Intake :- Pod filter with adaptor
Gearbox :- R33 GTS-T series 2 auto gearbox + torque converter ( stage 2 shift kit installed and has just had a recent gearbox service ) less than 100,000km on gearbox
Exhaust :- 6 into 2 into 1 Coby extractors , 3" highflow cat , 2.5" catback exhaust system also have a 2 1/4 " system for rego
Wheels :- 17x7 " SSA wheels currently on car
Suspention :- Pedders suspention all round , nolathane bush kit fitted , pedders rear swaybar , japanese front strut brace
Brakes :- standard rotors with new pads front and rear
Extras that come with the car :-
1 extra headlight and 2 indicators to fix the minor front end tap by (previous owner) hardly noticeable unless you really look
Front and rear 5 stud hub conversion with DBA crossdrilled and slotted rotors all round
2 sets of 4 piston calipers (R32 gtst and R33 GTR calipers)
1 set of 2 piston rear calipers
1 set of standard R32 GTS-T wheels (no tyres)
I also have a full BN sports Blister widebody kit that I have for the R32 which is brand new in gel coat never been fitted which I will sell for an extra $2000 ontop of the cost of the car as the kit is worth over $3500 there is only 3 of these kits in the country ... cost to import his kit from japan is close to $4500-5000 AUD
The car will come with am ACT roadworthy certificate and rego till 10/2010 for the happy new owner
I Will sell the car for $6000 with the extras and the kit will be $2000 ontop
so for $8000 you can get a widebody car perfect for an RB25DET conversion or drive it as is
And also as a testimate to the cars reliability these photos of the car were taken from my last trip down to geelong in victoria
I am a mechanic in the trade so I make sure the car is well looked after and serviced every 5000km
Perfect for a P plater or someone that just wants a good reliable daily driver
here are some pics of the kit
here is what is looks like on a couple other cars
https://www.sau.com.au/forums/topic/324389-fs-1992-r32-gts-skyline-6000/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
