Hey guys,
I just took off my valley cover today to try and keep my coilpack temps down, but now there is nowhere to mount the ignitor pack. People have said it's best to cut the valley cover to have this mounting point.
Just wondering what's the best way to do this at home? Will a hacksaw do the job? Or can i just leave the ignitor pack loose?
Cheers
Edited by rorz
https://www.sau.com.au/forums/topic/324760-best-diy-way-to-cut-coil-cover/
a valley cover is is for a v-type engine..u mean coil cover =) as for taking the cover off?? im not a fan, but leaving the ignitor loose wouldnt be a good idea, u maybe able to bolt it to were one of the coil cover bolts go?
Edited by 51NNA
Ah sorry, noob here.
Coil cover then. Yeah nah i tried doing that didn't work out. People cut the end of the cover off and keep it to mount the ignitor i know i could get it cut for me professionaly but i'd rather try do it at home it's just my tiny hacksaw isn't up to it
hey mate, i cut mine, its a soft alloy, so its really easy to do with a hacksaw. then simply file back to a smooth/square finish, and paint the whole thing.
rowdy.
p.s. there are plenty of lines getting around with barely restrained ignitor packs- even some of the show cars at superlap! every little detiail in the engine bay polished and cleaned, and a grubby old ignitor pack floating around on top of the coils.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
