That's actually the cause of 99.9% of shudder. It's called DTV (disc thickness variation) and is caused by cheap pads, and/or excessive float in wheel bearings... which leads to the pad material being laid down unevenly.
GSL - i've had that before, and it was clearly visible as differently coloured areas on the rotor. Is it always visible?
My money would still be on rotors. Could have been glazed, but I would still say they are warped...
But also check your tyre pressures. Happened to me on the weekend, felt like something was very very wrong, like the wheels were about to fall off, steering wheel shaking violently, car wasn't handling properly... Checked the tyre pressures the next day, and they had dropped quite low. Pumped em up to 38psi and that fixed all the problems. I doubt you are experiencing the same thing because my problems weren't while I was braking, more while I was cornering. But worth a go anyway.
Will have to check that out, better safe than sorry :)
It's VERY VERY rare that rotors actually warp. It simply doesn't happen, even on race cars. Even rally car that get them glowing hot then go through water spashes don't 'warp' rotors. It doesn't happen. It will be DTV. Machining them will fix the problem, but it often doesn't curing the underlying problem.
Commodores are really bad for shudder, and it's always excessive float in the bearings, which starts the problem, then the pad material being laid down unevenly on the rotor because it's not rotating square finishes it....
Some light reading by car engineer legend Carrol Smith:
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
I warped my standard rotors by getting the rotors hot and then sitting on the brake when I'm stationary, like at a traffic light?
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
