Alright guys clearing out my garage.
I have:
1x Rb20 head comes with rocker covers and cam gear cover, no gears has everything else (cams, valves etc) $200ono
1x Standard rb20 dump pipe $40
1x Standard rb20 intake with blowby holes bung'd up $20
6x Standard rb20 coilpacks $100
6x BCPR6ES- 11 plugs gapped to .8, only used once $15
1x Cefiro automatic antenna $100
Can email more pics
Located Gold Coast, Qld
Contact by PM or 0409706186
Joel
https://www.sau.com.au/forums/topic/325927-garage-cleanout/
I have:
1x Rb20 head comes with rocker covers and cam gear cover, no gears has everything else (cams, valves etc) SOLD
6x BCPR6ES- 11 plugs gapped to .8, only used once SOLD
1x Cefiro automatic antenna SOLD
Can email more pics
Joel
Refer to ^^
Also have a pair of 4x114.3 8mm slip on spacers $40
https://www.sau.com.au/forums/topic/325927-garage-cleanout/#findComment-5369351
