just doing head gasket atm, and their is coolant lines everywere on rb's.
Im sure you can do without many of them, i know def the tb one does not need to be connected.
But anyone else out their blocked any up before or know which i can block up ?
Any info muchly appreciated.
+1 for leave them
sure people will tell u u can make more power etc without coolant running through everything, but if bits r cold on the intake ur car will have bad fuel atomisation etc and might drive like a pig till warm. remember carby cars often run a heat riser tube off the exhaust manifold to the intake for this reason.
reminded me of the "mod" where u bypass the throttle body coolant hoses etc and people feel a gain in response and power etc! lol kinda odd considering the whole inlet manifold has coolant running through it!
hehe, at least ur doing it for logical/sensible reasons :)
as for getting rid of em, yes its a mess under there, and its been a while since i had a good look with a plenum off, might have to try and nut it out, or just change all the hoses to save headaches.
i had one in there let go, it was an absolute prick to change!
When I had my head off I redid some of the coolant lines by removing some and reconnecting others. It's a bit hard to describe it all but the easiest one to do is the throttle body coolant one and rejoining it elsewhere. That's one line you can piss off, don't need to worry about a buterfly sticking shut in Australia's climate.
I have had many let go over the years on my other 20's. its bullshit, And i really think they are not essential.
I will replace them all new if no1 knows, but i have heard of people removing/blocking a few.
Maybe because of the age of the lines, or becoming blocked?
What would nissan not know that you do?
This is about as far up there with mods such as filling the chassis rails with foam, or looping the battery fumes into the intake...
Battery fumes into intake?! :) rofl
Please ellaborate!
Kinda reminds of me of a wrx owner i was on the phone to, who wanted his ""screamer pipe" hooked up to the intake to his turbo"
Yes epic LOL
I explained u only do that if u want a nice fire in the engine bay and kindly suggested to bring it past and i'll have a look what he meant exactly what we might be able to do for him. He never turned up tho funnily enough! :(
Generic foam in chassis rails wont do squat, but u can get stuff more specific for the job that does apparantly work, off topic either way.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
