For Sale
1994 Nissan Laurel C34 Medalist V Turbo (LX Selection)
Specs on the model here ----> Nissan Laurel C34 INFO
This is, as far as I know, the only fully complied, registered and legal C34 Laurel in Australia. It has gone through the strict inspections at Regency in South Australia and passed. Perfect for someone who is looking for a very unique and legal import that can be used as a daily driver or for some spirited driving through the hills.
Mechanical:
RB25DET MANUAL (from an R33 Skyline), was originally an RB25DET Auto
Engine and Gbox have only 130 000kms (Odometer 212 000km)
New Bilstein Suspension all around
Exhaust with canon muffler
Nizmo 2-Way LSD
Short shift kit on Gearbox
ABS
Work 17inch rims
Front fog lamps
Complete option bodykit w/ moulded front lip, side skirts and rear pods
Registered until September 2010
Interior:
Top of the range Medallist model
Leather interior
Woodgrain dash
Electric windows, mirrors, seats
Electronic climate control
Alpine CD player
EcuTalk consult computer, Blue screen (Reads everything directly from the computer including fault codes. Also computes fuel consumption, 0-100 and 1/4mile times etc.) more info here ----> ECUTalk INFO
Central locking w/ Australian Standards immobiliser and Alarm system
Airbags
Tinted windows
Black two-tone paint
Spare parts:
Rear bumper – current one has some bumps and scratches from when the car was used in Japan. New one will need to be painted to match two-tone paint.
Gear shifter woodgrain surround – current one was modified during manual conversion. New one will also need to be modified.
Nissan FAST Software - this software allows you to find the Nissan part number of ANY part of the car, especially helpful because this car is so rare. It also has details of almost every Nissan released in Japan.
Condition:
This car is in great condition for its age and only has a few blemishes. Front driver and passenger seats have slight fading and cracking from sun damage. Rear seats are in great condition. Boot used to have a spoiler but has been removed and the mount holes are currently plugged up with rubber grommets. Paint is in great condition although there are some stone chips, as expected on the front, and the bumps as mentioned on the rear bar. Dash lights are a little dim during the day.
Pictures:
Price: PRICE DROP $14,500neg. No swaps. Finance Available, contact me for details!
Contact: PM, Reply or call 0416 143 662
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
