bump
- Alternator: $100
- AC Unit: $70
- AC/ heater blower motor: $80
- passenger kick panel: $30
- under dash trim panel: $30
- AC fan: $60
- 1 stock coilpack: $30
- driver seat: $100
- dash cluster surround: $30
- throttle body sensor [tps]: $50
- wiper/washer bottle: $40
- brand new front rotors(gone orange from sitting outside): $110
- front pipe: $60
- turbo(missing actuator) & dump pipe: $160
- injector resistor: $40
- steering column surround: $40
- dimister switch: $20
- hazards/tune switch: $20
- power steering pump: $80
- power steering resevoir: $30
- battery: $60
- oil dipstick: $15
- drive/fan etc. belts all 3(brand new): $50
- windscreen wipers all 3: $30
- pipe that goes from turbo to afm: $30
- bov return pipe: $50
- turbo heat sheild: $40
- centre console: $30
- orange passenger indicator(slight crack and scratch, still works): $40
- little airvent that goes from airbox to front of bonnet: $30
bump
- Alternator: $100
- AC Unit: $70
- AC fan: $60
- driver seat: $100
- front pipe: $60
- battery: $60
- oil dipstick: $15
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
