are they nice jap rims or just cheap ones? and how much do u wanna spend?
personally if they're a nice set of rims and u dont wanna skip on quality powdercoat them for a few hundred dollars
i wouldnt pay a few hundred just to paint them, paint scratches easily, a good quality paint wont scratch as easily but if its gonna cost you a few hundred dollars thats round about the same price to powdercoat them.
i painted my stockies with a very cheap brand spray can (primer then gloss black) about a year ago and they're still fine today no chips no faded paint its still surprisingly good haha and i wash the car regularly and drive it daily, and the best part about this way is it'll cost you $5, if u do hit a gutter or something u can always touch it up with the leftovers in the can using a brush and if u dont like how it looks just rub it down with thinners.
https://www.sau.com.au/forums/topic/326526-rim-painters/#findComment-5317801
Did some calling around myself a few weeks ago regarding this, this was probably the best I came up with:
Diamond Powder Coaters
2/51 Division St, Welshpool WA 6106‎ - (08) 9258 4355‎
Guy I spoke to was called Martin
Said that for $50 a rim they do: sandblast rim, primer and topcoat/powdercoat
Going to be getting my existing Advan AVS's done if the car doesn't sell in the next 2 weeks :rofl2:
https://www.sau.com.au/forums/topic/326526-rim-painters/#findComment-5321268
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
