Item Summary: DOMOKUN DOMO Key Ring Lanyard - Tow Hook Toy JDM Domo kun Drifter - Plush Toy
Condition: Used
Reason for Selling: Spreading DOMOKUN love
Asking Price: 15
Delivery Methods: PickUp or Postage - I think postage is like $3.40 or something + 90c for the bag, i'd have to check, can be done. Easily posted, trusted, check trader ratings :( - Also a member, so they've got my details.
Contact Info: Pm for number
Extra Information:
Domokun doll for your tow hook!
+ domokun lanyard for your keys/phone
Pictures below, just an example on my rear tow hook wrapped up. You can tie it there however you like.
Sorry about the photo quality, can't find my usual camera, so phone it is.
I've got a few, so buy them for yourself/friends/all your cars. Quick, as I only have two.
Note: I don't where you can get them and for how much, get them there then.
  • Replies 100
ill take both, pm me yo
Pm sent.
Can't edit first post.
- Posted one today, flat rate for 250g Aust wide:
$4.55 + $1.10 for the bag
Aust Post Charges as of 28th June sky rocketed.
I've got a few more now, so anyone interested, send me a pm.
Cheers
1 set includes the doll and the lanyard right?
If so, I'll take two sets if you have that many :) can you let me know how much total sent to Melbourne?
Cheers! DOMO :D
Edited by UnCo
Cheers! DOMO :D
Correct :)
1 set
- Domokun
- Lanyard
- Tags + phone attachment string
UnCo, 2 will be on their way to you tomorrow.
Have a few left now.
New better quality pictures:
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
