  • Replies 100
Charles, sent you a reply.
Australia Post has put their minimum postage price up >500g is now $4.75 Australia wide.
+ the bag.
Cheers
BUMP
  • 1 month later...
  • 1 month later...
can you please PM me price for a set plus postage to melb
Posted.
pm for payment details posted to 5014
Pm sent with details :)
AustPost has put their prices up again.
$5 is the baseline for >250g Fuuuu
Need better options.
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
