Hi all up for sale is a list of left over R32 Skyline parts and RB20 parts that all have to go.
All parts are out of a 1993 R32 Skyline that only had 86 xxxkm on the clock.
Clutch Fan $30
RB20 Stock Turbo with oil and water lines $300
Coil Packs with brackets $80
Water pump pulley $15
Fly wheel (Manual) $40
5 speed gearbox with shifter $450
Tail shaft (Manual) $50
Air con ompressor $40
Air on compressor braket and adj pulley $10
Starter Motor $40
Crank angle sensor $30
Cross over pipe (intake) $30
Brake Booster $30
Rear brakes calipers and disc rotors all $60
Power steering pump $40
Gear box exhaust bracket $20
Windscreen wiper motor $20
Throttle body with sensors $20
Whole Intake plenum with sensors $30
Fuel rail with injectors $40
Rear middle seat belt $10
Electric sunroof switch with light $40
Indicator stalk unit $40
Passenger side electric mirror (black) $50
Drivers window Regulator $70
Interior light $10
Fuel door (black) $30
Need all this gone. PM or contact me on Sam 0415126075
Located in Ashfield (Sydney)
Postage can be organised at buyers expense.
Cheers
Edited by Nissan r32
https://www.sau.com.au/forums/topic/327240-r32-rb20-skyline-parts/
Hi mate would like to buy the rear rotors, i will be in sydney next weekend could you text me your number, mine is 0447461636.
Is the gearbox in good conditions? does it change nice? i would like to buy the box as well will u take 300 for it and i will pick that up also next weekend.
Cheers
Dale
Edited by DR31FT
Hey mate, got the heater hoses? Got pics if you need.
Hi mate
Sorry I don't. You should be able to find universal ones at a spare parts shop brand new. Just take yours
with you so they can match them up. Thats what I did.
Cheers Sam
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
