hi all
recently ive had trouble with my rb25 since my regrettful turbo upgrade ive been told to add injectors and ECU into it to sort it ive bought a APEXI POWER FC and SARD 850cc injectors but im a bit worried about putting them into a stock engine i mean surely increased injection would make alot more heat and strain on the engine so what do i have to do to prevent it from exploding after i spent so much on it, forged pistons??
https://www.sau.com.au/forums/topic/327290-plz-dont-explode/
What turbo did you put on. That's the million dollar question.
Don't run an aftermarket turbo on the stock setup so yes injectors, fuel pump and ECU are a must at the minimum. Engines don't just explode. Detonation is what kills engines which all comes down to the tune. Having a large turbo on a car on a stock setup is a lot more dangerous than running a bigger turbo with all supporting mods keeping it all running right.
By the sounds of things i'm assuming it was just a slightly larger turbo upgrade, possibly highflow? Regarding your injector choice you may have gone a bit overkill, but once again, comes down to what turbo you put on there.
Need more information man.
You need to start reading the Forced Induction section to get a better understanding of it all.
EDIT: Don't worry I just found your other thread, i'll read that and reply in there.
Edited by PM-R33
the bigger injectors themselves aren't going affect the engine. you could put 10,000cc injectors on a stock engine and it won't affect it at all because you then tune the ecu to only allow the injectors to put in the same amount of fuel as it was before.
what will put more stress on the engine is the turbo. this then pumps more air into the engine, and therefore you have to put more fuel into the engine to balance it out.
so ok the injectors wont harm the engine bcos they are set to match the air intake with fuel (more air, more fuel) ok. what about a fuel regulator will the stock regulator be able to run injectors as big as 850cc coming from a stock setup or will it be wise to get an aftermarket fuel regulator if so which one?
as PM-R33 said, its all in the tune. normally if you have big injectors, a higher flowing fuel pump and bigger turbo you'll have to tune it anyway. you dont have to change the fpr for your application, its not really necessary unless for some reason you want to fine tune your fuel system or running ridiculous amount of power.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
