R31 executive Rb30 auto 3 litre beast.
280.000kms that’s early life for a r31.
Rego to October 10th.
Can supply rego I will be getting one soon in the next couple weeks if there is a serious buyer.
This is my daily I drive to work every day for the past 6 months. Has never had a problem at all.
Always serviced by myself or my mechanic.
Fantastic tow car towed my r32 to winton from hoppers crossing twice and not one problem or hassle at all.
Reason for selling is I have nearly completed my r32 to drive as a daily so won’t be needing this car.
Engine:
Bigger sump, cleaned and brand new Nissan oil pump can say it’s all brand new.
Head has been taken off and cleaned up.
Upgraded cams. Nothing extreme.
Engine bay is clean as a whistle,
Brand new bosch power steering pump
Brand new bosch alternator.
Brand new bosch belts x3.
Brand new bosch coil’s x6.
Brand new spark plugs x6.
Brand new radiator hoses.
Brand new water pump.
Brand new thermostat.
Brand new Nissan head gasket.
Brand new Nissan manifold and exhaust gaskets.
Brand new vacumme hoses, water lines, oil lines. Nearly every hose is brand new.
Gearbox:
Has been reconditioned everything is brand new in this gearbox and runs smooth as.
Brand new motul gearbox oil.
Diff:
standard diff.
brand new gearbox motul oil.
Suspension:
Brand new lowered king springs up front.
Standard rear choppies super low.
Has got heavy duty springs and shocks atm for towing. Cost over $500
Brand new front rods from bursons (forgot what brand).
Exhaust:
Stock all the way besides diff back is a 3 inch pipe its legal.
Wheels:
Unknown brand wheels. 17.8 +30, 17x8.5 +26. Bald tires will come with rwc tires from a roadworthy soon.
Interior:
stock blue seats everything is in good condition. No rips in seats nothing, floor is a blue fluffy material very nice.
Has 3 drift gauges water,oil temp, oil pressure,(not hooked up) from autobarn, big monster auto gauge tacho (working) from autobarn.
Sony headunit, with speakers and splits, all working.
All electrics, aircon/heater, lights, everything works. Besides roof little light lol I will fix that with a $2 globe.
exterior:
paint is really good. A light fade on the bonnet, roof and boot from the sun.
Painted black front bar and rear bar.
I have lots of spares. Wheels, pod, springs shocks.
pictures up soon guys
asking 3k at this point with rego and aftermarket springs, tow shocks and springs.
can take things off to make it cheaper.
only ring or sms me on 0430078630
located in victoria hoppers crossing
https://www.sau.com.au/forums/topic/327293-vic-r31-executive-rb30-auto-3-litre/
easy $500 for manuel conversion. i was going to do this but the auto is just in perfect condition cant just swap it and throw it out lol.
  • 4 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
