Hi guys,
Looking for a set of stock nissan rims such as gtr 32/33, v35, 350z r34 gtt/gts-t's ect etc etc..
Show me whats u guys got n on car shots would be better! I do prefer pick up from anywhere in melb..
Thanks
https://www.sau.com.au/forums/topic/327417-wtb-r3233-gtr-rims/
Hi guys,
Thanks
I have a set of R34 25GT rims in good condition. 16x7 +40 5 stud. 1 rim has a bit of a scratch on it. With tyres. $200 pickup from frankston\
Same as these.
Edited by synaptix
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
