Hi,
For sale is my immaculate midnight purple R33 GTR Vspec.
This car is in prestine condition, inside and out for its age. The paint is still factory! The seats do not have any marks or tears. This car needs to be seen to be appreciated. It has just been tuned by Hitman and its mid range, top end and torque is unbelievable. Absolute weapon of a street car and has been extremely well looked after, serviced every 5,000-10,000kms.
Model: 1995
Kms: 97,000
Modifications:
Engine:
Apexi DJETRO Power FC with hand controller
Apexi boost controller
R34 GTR N1 turbos
K&N panel air filter in orginal GTR airbox (previously had twin pods in cold air box but reverted back to factory, can provide previous set up)
Sard 700cc injectors
Sard fuel pressure regulator
Tomei exhuast manifold
Tomei dump pipes
High flow cat (also have standard cat and cat back exhaust for buyer)
3.5 inch cat back exhaust
OS Giken cam gears
Bosch 044 external fuel pump
Surge tank
oil catch can
Tuned by hitman at 20psi, making 324kws at the wheels (see dyno sheet)
Interior/Exterior
19*8.5 XHP Jet Crome wheels
Nismo 320km/h dash
Greddy turbo timer
Nissan alarm
Kenwood deck
Rotored discs
GTR key
Nismo shift knob
Original GTR kit with front lip
Price
$27,000 FIRM
Contact: 0410481565
https://www.sau.com.au/forums/topic/327440-r33-gtr-vspec/
  • 4 weeks later...
Hi,
How are you?
Few questions about the car, a mate has asked me to keep an eye out for clean 33 gtr's for him.
Does it have any suspension mods?
What type of clutch is in it?
2WD or 4WD dyno used for the run?
https://www.sau.com.au/forums/topic/327440-r33-gtr-vspec/#findComment-5418903
Hi,
How are you?
hey mate,
the car is extremely clean.
- it has standard shocks and lowered springs
- it has a button clutch
- 2WD dyno (im 99% sure) @ Hitman
Let me know of any more questions.
Thanks.
Anton
https://www.sau.com.au/forums/topic/327440-r33-gtr-vspec/#findComment-5423543
hey mate,
Thanks.
Anton
https://www.sau.com.au/forums/topic/327440-r33-gtr-vspec/#findComment-5443175
