What: Rb20det engine, includes, turbo, injectors, manifold and coilpacks
Where: Melbourne, Victoria, not keen on posting
Price: $800.00 ONO...just need it gone asap will sell cheap for quick sale!
Condition: It was running perfectly making 200rwkw with bolt ons, only reason I removed it as I couldn't sell my car as a whole and have since parted it out, this was the last thing remaining. Had a 100k service about 6months ago, new gates timing belt, water pump ect, always serviced with quality oils. Was originally in my 4door. had transferred into my 2door, 165,000km is about what on it, but its an rb20, pretty strong.
Pics...on request, has sprayed black rocker covers.
PM or msg 0400200997
Cheers.
https://www.sau.com.au/forums/topic/327564-rb20det-engine-complete/
need any brand new RB20 upgrades like injectors, coilpacks, turbo, radiator etc etc?
if you were keen i'd be happy to arrange a swap with something? only thing is i am in brisbane.
send me a PM if you are keen on anything
If your keen mate give me a call and leave a deposit. Otherwise still for sale. Some people have asked about postage...if you want to pay for it, I will put it on a pallet as long as you organise courers.
Thanks
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
