Hey guys,
My mate just rebuilt an RB30 using the RB25 head, its running a t3/t4 garrett turbo. A turbosmart pro gate is installed.
The problem being is the car loses boost, at the moment it will boost to 18psi and radically drop to 14psi where it will hold. The boost controller has been changed from a HKS EBC to the simple turbosmart T-Piece, but this has had no effect.
Before the external wastegate was installed the motor would only hold at 12psi.
Any ideas you guys could give me would be greatly appreciated.
* The boost we want to run to the motor is a constant 20psi.
https://www.sau.com.au/forums/topic/32780-help-losing-boost/
I dont know sorry. It was a suggestion as a quick fix. Reallistically I think there is a problem somewhere else, as I can get well over 10lbs adjustment with my external gate and it holds fine - I am not sure what spring it has, but I have run as low as 10psi, so softer than the one your mate has.
How is the gate plumbed up? Was the gate new, and if second hand, did you have it checked out before fitting it?
https://www.sau.com.au/forums/topic/32780-help-losing-boost/#findComment-658434
The gates plumbed up, it currently wastes to atmosphere, its brand new, and its been plumbed up to be controlled by the EVC, it was professionally installed, as well as tuned, after a smoke test they still cant find the leak.
I believe that the problem lays somewhere with the internal wastegate on the turbo not being disconnected correctly. Could this be possible?
https://www.sau.com.au/forums/topic/32780-help-losing-boost/#findComment-659092
What I dont understand is that it is making 18 and then dropping.
If it was internal gate, did they weld it shut, or wire it? If it still has the standard acutator in place, it is possible its leaking boost.
As for professionally plumbed, I have had some 'professionals' (they certainly charged like professionals) do some pretty ordinary things. When I had my gate first plumbed, he did it wrong and I had to sort it myself. That is only one example of several. Not that I am saying these guys didnt do a good job, but sometimes it pays to check the basics.
https://www.sau.com.au/forums/topic/32780-help-losing-boost/#findComment-659531
I had a Blitz SBC-iD EBC that had 2 modes.
Auto - Learn boost curve and adjust to suit
Manual - Percentage of max boost available.
The auto mode would manage to hold boost at 16psi up over 5500-6000rpm BUT it was struggling as the boost curve (as per the graph display) was a little wavy. The solanoids also showed that they were basically 99% closed over 5500-6000rpm in order to hold the boost I was asking it to.
The manual mode would have boost come up (16psi) and hold perfectly flat until around 5500-6000rpm it would then drop to around 13psi.
I've also had a VG30BB turbo that has a large .81 or what ever it is exhaust housing. Exactly the same thing. Boost drop over 5500-6000rpm. I tried both the RB20t 10psi wastegate and the VG30 6-7psi wastegate on the VG30 turbo.
The weaker wastegate (VG30) the most boost I could get the car to hold with a bleeder or in manual EBC mode was around 10-11psi, in auto mode it would hold ~14psi but not 16psi.
I think its got a lot to do with the strength of the wastegate spring not so much back pressure as back pressure is always going to be there. Tim from RPM did a comparison and saw no difference once on full boost between a ~.81 & ~1.01 with regards to back pressure in the turbo housing, it always hung around the 2 x inlet pressure. This was on a 900hp VL Turbo.
https://www.sau.com.au/forums/topic/32780-help-losing-boost/#findComment-659561
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
